Another shot of the flat "hood" and cheeks, that were cut off...
Here's a shot of the strut attach points. I added a bit of ply to go over the top of the longeron, and used a blind nut to make sure things are strong.
Mount points on the wing got the same treatment. Counter bored the hole for a blind nut, then ran a tap through the T nut so the wood would also be threaded, and clocked to the steel threads of the T nut.
In the photo you can also see LED's mounted inside the wing, and clear plastic tubes for servo wire guides (the tubes oxy aceteline welding rod comes in).
Here's the glider release. It is mounted to the fuse via screws on the top into the structure the wing mounts to, and on the bottom it has 4-40 allen screws into T nuts.
