Originally Posted by
Dblex
I agree! Share your details buddy!
Sure, Hi,
On elevators they were JR 32 something. Used them on my Bandit ARF too becasue they were the only ones that would fit, and on a Tamjets F-16. I now have HS-5625MGs, they provide a little bit more torque if you use 6V.
Ailerons I use 5245MG, so easy to install. I know people who have used Hitec thin wing servos succesfully on ailerons, they are barely 60 in-oz. I'd only use those if you are 100% sure you will never use ailerons as flaps.
Then for rudder I use JR Thin Wing digital DS-398. You could go HiTec, thin wing but I'd rather have the extra 20 in-oz since I do use rudder a lot, and at high speed.
This is a proven combination, that doesnt require a lot of power. I probably use between 250-400 Mah per flight, including a power thirsty EV5A valve.
Keep em light, fly em right. ;-)
David
