Originally Posted by
jetmech05
You sure about the kill switch using the signal wire? Or is it that the kill switch just uses the power.
I believe the OP is asking about how to connect to the RX,m not how to power the module
Most power the ignition module with a separate battery pack as intended, I'm pretty the wire to the RX only powers the switch function and it will not power up the module.
Even if it did and you could power it that way the kill function still needs it's own TX to RX channel function so the only thing you can feasibly "Y" it to would be the RX power input.
I think you're confusing a IBEC with an Optikill switch, the IBEC would get power from the RX pack.
