Os fs 26
Tue response---That's the info I was looking for! Thanks! I have 2 of these engines that I recently received from friends. I have one mounted on a test mount and the other is waiting attention. It dawned on me. after reading your note that the hole may be plugged. I'll check that out in the morning and let you know. I think I'll replace the glow plugs too. Thanks again! Doc
Wed afternoon---I set the air bleeds as instructed, installed new glow plugs in each. The one engine runs much better and is responsive to throttle position but still I can't get up to the 11,000 to 12,000. The other is running fine! Maybe a bit more tweaking with the air bleed adjustment.
Thanks again for your help! Any more suggestions will be appreciated! Doc
