Not sure what you are using as an apple but it must be Tamiya compatible. The stock HL and Taigen apples will not work as the pin out on the IR receiver chip is different.
You need to be sure the Sensor you are using has the following pinout. Anything different will result in LED that won't flash to indicate the programming is actually worklng.
