Taigen Tank TK22 problems.
#76
I just fitted an 8pin/socket JST LI-PO balance plug cable in my Taigen Tiger 1 Clark board it connects to the existing cable and lets me take the Tank Body/Turret off of the Hull and lay it down while still hooked up.
Allowing all manner of work to be done with the Tank open and yet still connected.
I have bulkheads on all my Tanks which keeps the gearboxes apart from the rest of the hull and keeps any flying lubricant away from the control board and it also stops the extended cable from getting into the gears. shaun
#77
Max, Hi, I live in the UK so I got them from this UK E-BAY site you need the Male/Female "8" pin/socket.
www.ebay.co.uk/itm/lipo-balance...35cc9doff3
I ordered 2 cables on Sunday evening and they came this Tuesday morning! and including postage £5.50.
If you have a problem try E-BAY /and look for Lipo balance extension charger cable lead 7s JST-XH (7 cell 25.9V) it is sold by "inhelume" Good luck shaun
#79
Yes.
I spoke to someone about this and because I mentioned LI-Po balance cable they assumed it was all the cable could be used for.
But of course you can use it any way you want,
An extension cable is what I wanted and this does the job perfectly
shaun
shaun
#80
Tanker 10 I just cut the 5 pin down to a 2 and 1 pin flipped to match the correct orientation shown in pictures, and plugged in. Works perfectly.
This is just until I receive the proper 3 pin. Used a drumel tool to shave down the plastic guides to fit.
Have a good one,
Have a good one,
#81
Have a good one,
Have a good one,
