Great old thread, I do the same thing but as the ghost of David Reid said, make sure the hinges line up. I usually pull the screws out of the hinges and drill them out for a wire hinge pin that runs through all of the hinges, and use it when gluing the bases down. As Falconwings says getting that hinge as close to the fuse as possible helps, great tip.
