RCU Forums - View Single Post - Taigen Tank TK22 problems.
Old 08-23-2015 | 09:41 AM
  #41
Shorty54
I had issues with wiring my Clarks in my T34 and Sherman because of the 360 turret wiring, I ended up bypassing some of the wires and running my own. Actually when I hooked it up stock, some wires began to smoke! I also have the Clark Elevation recoil kit in my tiger. Its ok, it took me alot of work to get it dialed in. Its made from 3D printed material and I found it to be very brittle. To me it took alot of cleanup on the parts to make them work smoothly. It may be normal, Ive never worked with 3D printed plastic. My gears have cracked and broke, I epoxied them and some of the the other parts and that has helped. The elevation is way too fast, you need to slow down the servo. Im going to try and build my own for my HL Tiger I. My Taigen Tiger with TK22 will sometimes fire the main gun when I shut off the TX.
