RCU Forums - View Single Post - OXAI Final's Touch EP - Assembly
Old 08-25-2015 | 06:02 PM
  #40
radioflyer9
Originally Posted by rbarthur
Mike,
I found the problem as to why the engine won't arm. The throttle channel was not working. After exhausting every logical senario and consulting with known professionals, I decided to switch receivers and "voila" after linking the other receiver and programming the engine per the instruction sheet. The engine armed and ran perfectly. Now the only question remains is the setting for the gear ratio. Mine is set at 1.5 to1. Is it the correct ratio? what ratio are you using?
The OS speed controller should be set at 6.7:1 ratio for the OS belt drive motor as that is the gear ratio of the unit. Just as Steve said.
Sorry for the delay,
Mike
