RCU Forums - View Single Post - C-ARF Integral with DLE35RA
Old 08-29-2015 | 07:43 AM
  #41
apereira's Avatar
apereira
Hello guys,
I was just reading the old posts and noted the kill switch accidentally being activated in flight, may I suggest you guys make a logic mix so unless the throttle is at idle the kill sw will not work?, this is the same as the throttle cut but on a on/off channel activation separate from the throttle.
Regards
