Originally Posted by
tailskid
The BEST pushrod IMHO is made out of the same material as the fuselage....so if you have a balsa fuse, use a (hard) balsa pushrod....fuse is fiberglass...use a fiberglass pushrod, etc....that is if it is possible
I just have to ask???????????????? I'm sure there is a good reason, I just don't know it but an inquiring mind wants to know. I only have one glass fuse plane and can't recall what was used as a push rod but I will look. I have never had a kit give me a balsa push rod but I have had them offer the hardwood dowel. I know my CG Extra has two dowels for the elevator halves. Not sure if I did that myself or not, that plane is a couple decades old.
