RCU Forums - View Single Post - Plastic control rods causing trims changes....
Old 09-13-2015 | 10:57 AM
Steve Percifield's Avatar
Steve Percifield
My Feedback: (14)
Originally Posted by jeff4912
I recently built a Sig 4 Star 60 and really enjoy flying it, but have noticed on warm days, that the control rods to the elevator and rudder expand causing changes to the trim settings. The control rods are plastic.
I don't have the problem with the ailerons because they are steel rods.
My question is: can I replace the plastic rods with steel 2-56 rods without causing a interference problem with the airplanes receiver? I imagine that steel control rods would solve the trim change problems.
Thank you.
I'm not going to read all the answers. I had the same problem. I replace the inner plastic rod with a 1/16" piece of music wire with clevises soldered to bothe ends, Cured the problem. The old Sig plastic pushrods were especially susceptible to the temp.
