RE: Cable soldering problems?
Yeah, Egor Sullivan has the coated cable and I agree it is the easiest to work with. Mich, or should I say mish? The only deal with silver solder is you need about 3 times the heat for a good flow. You are correct though it is much stronger and is my choice for connecting wire landing gear and other areas that need alot of strength.
