 Cable soldering problems? >
Old 10-17-2003 | 07:36 PM
Default RE: Cable soldering problems?
Rajul:
Not positive but believe it to be sullivan flexible push cable Just checked towers site, and the teck note dosen't say that it is brass coated. I do believe that this is the cable I used. Got mine a LHS and can only find about a 16" piece with the plastic sheath, no package.
Egor
Old 10-17-2003 | 08:12 PM
vicman's Avatar
My Feedback: (10)
Yeah, Egor Sullivan has the coated cable and I agree it is the easiest to work with. Mich, or should I say mish? The only deal with silver solder is you need about 3 times the heat for a good flow. You are correct though it is much stronger and is my choice for connecting wire landing gear and other areas that need alot of strength.
