Originally Posted by
52larry52
Tom, So do you not thin the 2 hr epoxy? On my last engine compartment fuel proofing I tried your suggestion (made on another thread a short while back) to heat the epoxy with a heat gun but saw only a marginal improvement in finished surface smoothness. I didn't understand that I was supposed to heat the compartment before I put the epoxy on, I just heated it after I brushed it on. I also was using 30 min. epoxy thinned with 90% alcohol. I will try it again on my next build, whenever that is, so should I seek out 2 hour epoxy and not thin it? Do you use the heat gun on the surface before and on the applied epoxy after? Thanks for your help, Larry
Use acetone not alcohol. Warm the area to be painted first. Mix the epoxy and then warm it too. NB small quantities of epoxy 2 hr or more.
