RCU Forums - View Single Post - fixing broken wing spars (actually ribs)
Old 10-17-2003 | 11:06 PM
  #34
Balsa Master's Avatar
Balsa Master
Default RE: fixing broken wing spars (actually ribs)
patch up all this and it should be ok, buy i really sugest rebuilding it (you probably added 2 or 3 oz with all that CA) or finish learning with this one then buy a low wing and fly this one till it buries itdelf for you, saves you some time :-)
note that i the pics were compressed so the writing loks poor and mispelled.
also if you can wait a couple days ill post some pics i took and show you sheeting, or if you get it deom the explanation earlier thats ok too.sheeting makes the ribs into I beams making them less likely to twist and crush.
ID:	68324   Click image for larger version
