RCU Forums - View Single Post - big block revo help!
Old 09-23-2015 | 10:59 AM
Maj_Overdrive's Avatar
Maj_Overdrive
You only need 3ch if you use reverse, otherwise 2ch is fine. The micro servo is the reverse servo if so equipped. Go to Traxxas.command have a look at some of the exploded views to see you the reverse linkage is setup. I don't see any of the required reverse linkage parts so it may have been converted to forward only. Many big blocks were as reverse makes the transmission a little weaker.
