RCU Forums - View Single Post - Help with lipo receiver pack
Old 09-23-2015 | 02:51 PM
jester_s1
Moderator
You can't run the receiver/servos and the ignition on the same circuit. You'll get interference that way. You'll need an optical isolator for the ignition. The simple way is to run an optical kill switch which will both isolate the the ignition circuit and give you a way to shut off the engine with your radio. Then you'll have a choice between running both circuits from one BEC or using separate ones.
