Dle 30, 6 hitec 5645s, ar8000rx
I think the ignition and rx are good up to like 9 volts but if I have to regulate the servos the rx would have to be regulated to right? I found this on hk but don't know if 5 amps would be enough,
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Says you can run 2 lipos 2 rx and such so I was hoping I could use one for rx and one for ignition
