RCU Forums - View Single Post - DLE Problems
Thread: DLE Problems
Old 09-25-2015 | 06:20 AM
dirtybird
Default DLE Problems
Originally Posted by BadAzzMaxx
The problem with the double spark on the RCexl sensors has been going on for over a year, there are a couple of the well known RC engines that have gone with a different ignition company because of the problem.
When I found the problem I started replacing the sensor on the RCexl when I sell and have not had a problem with the ignitions.
The only RCexl ignition I sell are the twin ignitions and got a new order last week and they still have the problem sensors with them.
On the timing, If you can not believe the manufacture who can you believe.
Milton
I recently purchased a twin ignition from you. I set the timing at 29 degrees with a dial indicator. I cannot get the engine to rev up over 4K.
If I open the throttle more it quits. I have checked out the tank and installed a carb that worked ok on another engine
Could that pick up be a problem? the engine is an RCS44B2
