Originally Posted by
jwrich
Thank you Carlos for your work with these engines. I still have a problem understanding what is the best setting to run these DLE engines. I have two DLE 35 and one DLE 30 plus a CRCR 26 and RCGF 15. I have always run Zenoah engines, 38s & 26, with the magnito system. I am currently running one 35 with no problems, so I have not mess with it. However, the DLE 30 has never run right, at first I thought it was the carb. So I ordered a new Walbro carb from Valley View RC, still not right. So I will try to check the firing with the degree wheel.
I see you are still flying the Citabria. Mine crashed because of radio failure, total loss.
Thanks again
Rich
I bought a ring for my DLE 30 from Frank Borman. With the instructions that came with the ring was that the Chinese engines need the bottom end cleaned up to remove any machining errors.
