RCU Forums - View Single Post - Tools?
Thread: Tools?
Old 10-18-2003 | 08:01 AM
im_a_rcav8r
Default RE: Tools?
In most cases you will need a 8mm socket for the glow plug. A 10mm for the prop nut. Small flat and Phillips screw drivers. A metric and Standard Allen wrench set with sizes like 2.5mm, 3mm, 3/32 etc. Some CA will come in handy at the field some times. Pliers stub nose and pointed nose. Side cuts fro cutting piano wire. I'm sure I have missed some, but that will get you started.
good luck[8D]
