Tools?
i would like some input as to what tools i should have on hand when i get a trainer. i would just need those to do the minor tweaks etc. i apperciate the inputs in advance thanks!
FL
In most cases you will need a 8mm socket for the glow plug. A 10mm for the prop nut. Small flat and Phillips screw drivers. A metric and Standard Allen wrench set with sizes like 2.5mm, 3mm, 3/32 etc. Some CA will come in handy at the field some times. Pliers stub nose and pointed nose. Side cuts fro cutting piano wire. I'm sure I have missed some, but that will get you started.
good luck
[8D]
good luck
[8D]
probably arf since you willl have to do some work that the manufacture cant charge you for doing.
if your not pressed really bad for time i recomend build ing a kit. see my sig.
