RCU Forums - View Single Post - Goldwing 60" sbach help
Old 10-05-2015 | 06:10 AM
imblaze88
I've always used the spar but I went back and checked the manual, it says 106mm which puts it right in the center of the wing tube which is actually a little behind the spar. But since the wing is tapered it depends where you measure from, I'm measuring right against the fuse. I hope it will be ok there last thing I want to do is fly tail heavy.
