RCU Forums - View Single Post - Broken wing dowel
Old 10-18-2003 | 01:52 PM
tashley's Avatar
tashley
My Feedback: (9)
Default Broken wing dowel
To remove a broken wing dowel, select a piece of brass tubing with an i.d. slightly larger than the dowel. Cut teeth on the end of the tube with a small triangle file. Chuck the tube up in your favorite drill. Slide the tube over the wing dowel and cut the glue away from the dowel and the dowel will come right out.
Tom
