Originally Posted by
av8tor1977
Hi Jim,
One, you might already know this, but never use grinding stones on magnesium or aluminum. They will quickly clog up, then will overheat and can explode. Use carbide cutters only. Then as far as magnesium itself, yes you must be careful. Magnesium grindings or shavings can be accidentally set on fire by a spark, and it burns white hot with a fire that cannot be put out with water. So you need to clean up often and safely dispose of it. If you do not let too much accumulate at a time, you'll be fine.
Here is my post and pics of the Stihl 62cc that I converted.
http://www.rcuniverse.com/forum/engi...challenge.html
AV8TOR
I did not know that about the magnesium cutting precautions, many thanks for that. I will have to chase up some carbide cutters and a suitable power tool to do the job. Maybe a carbide blade for my little 4 inch grinder is available? I only have a carbide blade for a 71/4 in power saw, which is far too big.
Thanks for the link to your thread above. I had seen it, but not studied it closely enough. The principle will be very similar. I was a bit stumped by the challenge of making up an intake manifold adapter; your idea is neat and simple enough for me to copy.
