RCU Forums - View Single Post - Help Starting .15 marine engine for first boat build
Old 10-14-2015 | 05:53 AM
wholehog
Originally Posted by jeffb2468
Thanks for the quick replys I will give it a shot with the glow plug not as tight. I originally tried tarting it to the left but every time the nut/screw that holds the flywheel would twist out. I will get a starter and try with that. What are your thoughts on the glow plug and nitro percentage? Thanks.
For what you are doing, 20 or 30 percent should be fine with a hot plug. As for a prop, a guy named Chris at [email protected] should be able to help you out with that.
