RCU Forums - View Single Post - HL Leopard 2 Restoration Project
Old 10-15-2015 | 11:59 AM
Rebel 1's Avatar
Rebel 1
Default The Repairs Begin
Hi Everyone,
Last night I labeled a few wires in the turret and proceeded to cut the servo wires. I'm going to get two servo extensions and cut the ends off of them. Then I'll solder them to the servo wires where I cut them. By doing this, I'll be able to test the servo's and the gun mount using an extra 2 channel RC system I have. Also I'll be able to unplug the servo's if they need repair or replacing.
I'm still going to try and clean up the wires and make a wiring schematic drawing to help me the next owner if I decide to ell the tank. Upon closer inspection, I noticed more of the slip-ring wires are not being used. I like the way mcm308 wired his Leo turret. I think I may do my similar to the way he did his. The best thing about somewhat copying mcm308 is the servo wires will plug intop the CB inside the turret and they will no longer be attached to the slip-ring like they are now.
There's also a tab broken off of the end of the 3DP gun body that I'll be gluing on as well as using two 0-80 screws to strengthen it so it doesn't break again.
On the back end of the gun body is a broken tab that supports the recoil servo. I'll glue and screw the tab back on for extra strength.
Name:	IMG_7714 13 x 8.6 LR Text Added.jpg
ID:	2125497   Click image for larger version
Name:	IMG_7715 13 x 8 LR.jpg
ID:	2125498   Click image for larger version
Name:	IMG_7716 13 x 8 LR Text Added.jpg
ID:	2125499   Click image for larger version
Name:	IMG_7718 13 x 8 LR Text Added.jpg
ID:	2125500   Click image for larger version
Name:	IMG_7719 13 x 8.6 LR.jpg
