RCU Forums - View Single Post - HL Leopard 2 Restoration Project
Old 10-15-2015 | 12:44 PM
mcm308
I like everything in the turret, was not my original plan but when I got the Clark board with GBS, the GBS unit needs to be mounted in the turret like I have and level. That required the main board to also be in the turret because the supplied wires with plug for GBS is very short. So everything ended up in the turret, Clark boards, receiver, Benedini TBS mini, and the audio amp. Only problem with this layout is, the motor, battery and speaker wires now run from bottom to top. I dont have a slip ring but right now I have ample slack for quite a few turns before I run into a problem and have to reverse the turret..lol That is the problem I need to figure something out with. Im not sure what kind of wires or amps those slip rings can handle. Never seen one before.
And I have Deans plugs on the motors and battery, and used male and female servo plugs for the speaker connections for when I need to remove the top.
If you buy a 10 pack of servo extension wires, they have male and females you can hack up a few like I did and use for quick connects.
