RE: Cor-Star 60 Version 2.0 plans and pics
Now your talents will be challenged. You need to make a template of the wing's airfoil to cut the wing saddle. Use heavy paper, draw and cut. You want 0 degrees of incidence on the wing, so draw a centerline, and get your wing saddle position. The LE of the wing should be about 7 1/2" - 8" (depending on the weight of your engine) from the front of the firewall. If you don't get this cut perfect, have no fear. A few degrees of incidence can be corrected by shimming the motor mount.
