RE: Cor-Star 60 Version 2.0 plans and pics
Plywood braces. These next two pieces serve as the landing gear block, and forward wing bolt reinforcement. They are made of 1/4 inch ply. Cut two pieces 3 X 6 1/2 inches.Lay them in the LG block, keeping the edges square where they meet. Trace your airfoil, and cut it out of the ply. Cut a 45 degree angle off right above the Fornt of it by the LG block, back. The following pic shows this gussett. Yours will not have a notch cut out above the airfoil like this one. The reason I did it like this on this one, was because I experimented by making my wing bolts farther apart than I originally stated. This left no room for the 1/4 ply reinforcement, so I cut around the wing blocks.
When you are happy with how everything fits, epoxy both sides to the inside of the fuse.
