RE: Cor-Star 60 Version 2.0 plans and pics
Rear wing plates.
This is the same dimension as the LG block, only not as wide because it will fit inside the assembly, and inside the 1/8 lite ply where the balsa stock butt joins. Get this plate glued in and gusseted with balsa triangle stock.
