RCU Forums - View Single Post - Ys 185 dz
Thread: Ys 185 dz
Old 10-23-2015 | 01:31 AM
  #82
drac1's Avatar
drac1
I flew the 21 X 10.5PN this afternoon. In short - Perfect match for the 185cdi. The Valiant is just under 5kg's, so it isn't a light weight model either.
I used the exact same setup as for the 20.5 X 10PN. I didn't even have to adjust the mixtures, which probably means I was still a bit too rich on both.
Idle is a rock steady 1700, which is similar to the 20.5 X 10 but more stable. Throttle trim position is unchanged also. Top RPM was 7300 for the 20.5 X 10. The 21 X 10.5 killed 500 RPM and now sits at 6800. Noise at full throttle is noticeably less which is a result of the reduced revs. It's a much more pleasant throaty roar.
As far as flying, well, it just does it better than the 20.5 X 10. The plane tracks better and requires less throttle stick movement, which means a reduced work load. I pull into a vertical the same as with the 20.5 and feed on the power as usual. There's no need to throttle up earlier. The difference is I stop at around 5/8ths throttle and just leave it there. It doesn't slow down at all, just keeps pulling until it's time to push over or whatever. Throttle control for the figure 9 with 4 point roll up also uses the same technique. Basically set and forget. Down lines are more constant speed as well.
With the 20.5, I had to be more aware of throttle control coming down the back side of loops as the engine rpm would increase noticeably. With the 21 X 10.5 it doesn't do this.
This prop makes really good use of the mid range torque that the cdi produces.
I have a gut feeling that fuel consumption is less also. It's certainly no worse. Really looking forward to getting some more flights with it over the next few days.
