RCU Forums - View Single Post - New Extra 330SC 2,33mt by Flight-Model
Old 10-26-2015 | 10:58 AM
sandrocacciola's Avatar
sandrocacciola
The construction work is slowly...
Install servos in the wing and quote is simpe. As you can see from the picture the terminal of stabilizer is in carbon fiber and in carbon fiber is the internal pipe; these is the same for the wings. This give greater rigidity and robustness in the area of attack with the fuselage. All movement are on uniball and the brackets are doubles and in carbon fiber. Auctions are already suitable ...
In the aileron I mounted two Graupner DES 707 BBMG; in the wings two Savox 1258TG and for rudder I install a Savox 1230SG.
ID:	2127773   Click image for larger version
ID:	2127774   Click image for larger version
ID:	2127775   Click image for larger version
ID:	2127776   Click image for larger version
