It's just like gorilla glue but less foaming. I spread the glue on the wood only, put everything together and in the sandwich for a few minutes with weight on it.... Then pulled ask the wood back off and lightly misted water above the bench and reassembled. This way I could look at the foam and make sure there was plenty of glue transfer. This glue is slow but says it will work on pretty much anything
