RCU Forums - View Single Post - sig hog-bipe question...
Old 10-19-2003 | 10:08 AM
techsarge
Default sig hog-bipe question...
I'll be using ultracote to cover the hog-bipe and wasn't sure about the abs rear turtledeck behind the cockpit. Did you hog-bipe builders use an iron-on covering for that section, and if so, did you do anything special to prep that piece? Or did you use ultracote paint instead?
Thanks...
Ed
