RCU Forums - View Single Post - New Extra 330SC 2,33mt by Flight-Model
Thread
11-10-2015 | 10:42 AM
14
sandrocacciola
Aug 2006
271
1 Post
Grosseto, ITALY
With an engine as the good DA-70 could not miss two good propellers.: I chose Mejzlik (
www.mejzlik.eu
). The choice to mount a carbon prop compared to a wood prop is certainly influenced by a part from the aesthetic side and on the other by the awareness to having, with that prop carbon, an engine more fluid for “effect flywheel” on the engine. In these test I have rthe opportunity to check the difference with the new engine and a beautiful 24x8 and 24x10 Mejzlik prop. The Mejzlik (
www.mejzlik.eu
) is a "must" in this sector with its products which are used by some best pilot in the world. A very high quality product, made in carbon fiber unidirectional and bi-directional and epoxy. Light, super strong, with central surface "hard" for drilled safely. The profile of the prop is optimized for maximum performance at a low level of noise and vibration. The propellers Mejzlik, get balanced at the factory buti s good idea che kit after drill… . As you can see in the picture I purchased from Mejzlik also trhe drillo guide accessory for drill correctly and without errors the prop. There are several “drill guide” for different engines. These accessory can not miss in the laboratory!
Reply
Like
sandrocacciola
View Public Profile
Send a private message to sandrocacciola
Find More Posts by sandrocacciola
View iTrader Profile
