Here are a couple of pictures. On the first one that I built, the gear sat in center of the cut out for little gear door and after doing the linkage, there was ample room for the section of the gear door that gets attached to the strut. But on this one and in one wing, the gear mount is off center a little. Also the linkage that opens and closes the little door properly makes the little door sit against the strut when the gear is down. So there would be no way for the section that gets attached to the strut to be there or work. I have tried to understand why it is not working and why I can't seem to be getting a length for the linkage that would make if work properly.
Behzad
