Thank you aghost..
Working on the tailwheel / tail assembly today. Does another hole need to be drilled in the tail wheel control horn? It does not look like the clevis will reach/ connect to the horn. The current alignment does not look like its going to work.
I also am having to shim the tail wheel bracket as the rod going to the rudder binds when the attach screw are drawn tight.
Just curious if you all worked around these defects?
