as stated, try new fuel, check inside the fuel tank and delivery lines for a pinhole leak, check the case for an air leak, check the carb is clean, make sure your needle valve isnt vibrating with that collar on it. I have seen them start to leak at certain rpm due to a harmonic vibration, let in air and poof deadstick. Put a piece of fuel tubing over the threads to help stop this.
