Originally Posted by
RBACONS
Is the fuel tank mounted too low in relation to the carb? It may be fine when full but have trouble drawing fuel as the tank level diminishes. I've also seen engines where the pressure tap was obstructed (from the factory) leading to poor fuel draw.
There isn't any play where the fuel tank is installed. It is a very snug fit on the Escapade changing the level where it it sits would require some modding.
