RCU Forums - View Single Post - Tamiya Pershing
Thread: Tamiya Pershing
Old 12-09-2015 | 08:21 AM
Tanker 10's Avatar
Tanker 10
Originally Posted by DaveBcool
It is my understanding the Pershing has the tightest fit by far.
If you look at the top front of the speaker, you will notice a 1/2 circle cut-out.
That is so the turret ring will clear the speaker, that's how tight it is.
You have to position the MFU/DMD just right, so the ring can rotate between the fuses on top and the guide wheels.
It helps to mount the DMD/MFU to the plate w/ velcro instead of the foam tape.
It is a mm or 2 taller, but that way you can re-position it easily.
Some guys leave out the mount plate all together to gain 1/4 inch of clearance or so.
But I kept it, and found it helpful to run wires underneath.
OK, looking at the speaker now I see what you mean by cut out. Thanks for the info.
