RCU Forums - View Single Post - BJ Craft Agenda CD
Old 12-14-2015 | 08:53 AM
AmericanSpectre505's Avatar
AmericanSpectre505
Herb,
How do you order the extra wings? I have inquired about a pair of the Agenda wings for the Invitation before I order mine. I do not want to fly the stock wings for the P/F-17 schedule or the K maneuvers.
I wish I could get my fingers on a Contra to see if I like it or not, until then I will stick with my plan. I know flying the DTFS wings -VS- the stock wings on the Nuance was a night and day difference in performance ability, favor going to the DTFS wings. However, with that said..., the DTFS wings had it's own set of disadvantage with that air frame. These are not DTFS wings but it's the example of substituting and experimenting for performance.
Good to know you substituted the wings and found better performance.
Bill H.
FAI/F3A/ Dist-2.
Originally Posted by HerbK
I have been flying the Inspire with the Agenda wings as that is one of the primary differences between the two planes. I bought an Inspire from F3A that had been damaged in shipping and needed new wings. BJ suggested trying the Agenda wing and he would cover it like the Inspire. If you lay the two wing panels on top of each other the Agenda wing has pretty much the same lines and airfoil but each panel is approximately 1 CM shorter. In the air this means that snaps are a little tighter and spin entries and exits are cleaner. The Inspire wing had a tendency to tip stall or drop a wing making the spin entries a little more difficult to control in all conditions. So far the Agenda wing doesn't seem to do that. The Inspire would carry a little momentum on exit while the Agenda wing helps the plane stop upon release of controls. Haven't noticed much downside. Probably means next plane is the whole Agenda.
Herb
