Walls and waterfalls were great but when I tried a parachute and flip-flop type parachute (whatever that's called) it would only go to 45 degrees nose down so I am hoping moving the CofG should help improve this.
Kevin, you need to blip the power on the falling leaf manouvre to maintain the momentum... take a bit of practice.
Well Philly... well done you, you did it ! The first ever Capiche 50 Fun......mor epictures if you will...
tell us more all about it... it you think it is a winner then a wing kit will be produced...
Andy, I know they are well under the 30 mark but I would say Furabas new 3010 is, as Philly suggests, probably the best ecomony bet.... otherwise you got 9202a bu they are 30 something I think, and then you head up again.
I think the 3010 is a fine match for competent pilots.
