RE: CA Hinge vs. Robart
I'd stick with the CA hinges. You'll get several diferent answers as this is usually a personal preference. When installed correctly, the CA hinges are quite adequate. if you're unsure about the proper installation, just run a search for CA Hinges. There's a ton of info out there. Good luck with your build.
