One last thing about sanding primer. I do not use a block to sand primer. If you do, it's assured you will cut through the primer. I sand all primer by hand with the sand paper folded into thirds. When you get the primer down to the point you start to see grain, you will just be sanding (focusing) on the small opaque areas and stay off the thin spots.
