RCU Forums - View Single Post - Turbine setup with a JR28x
Old 12-22-2015 | 05:18 AM
wfield0455's Avatar
wfield0455
My Feedback: (7)
Originally Posted by Airman98
My understanding is that if failsafe is set at your normal kill then if you get a temp loss of signal your turbine will shut down immediately but if it goes to a range outside of normal the ecu waits 2 sec to see if signal is regained before shutting down.
That is correct, and unless you set your failsafe value outside the normal operating range, this behavior will never happen, you'll have only the radios failsafe setting, no 2 or 3 second delay and no log in the ECU indicating what happened.
