Matt,
It should do great for you. Even the little 14 inch guy should work fine as you can turn the graphic on it's side and cut it the long way. The wing graphics on my Porteus is something like 8 inches by 27 or so. In this case you just rotate it 90 degrees and you can print (cut) it on a small machine. I have not seen the cut quality of the little guy, but I would think it would be the same as mine.
The big hassle is finding someone to buy the masking film in smaller quantities than a full roll. It may take some legwork on the interweb to find someone.
These folks carry Oramask and GT. I haven't used them so you would need to do a bit of research.
http://www.hhsignsupply.com/productc...0&keyword=mask
