Originally Posted by
Roboticus_Prime
Do you have the steel gears in your Sherman?
Yes, but they're 3 shaft. I have a set of 4 shaft V2 gearboxes for it, just haven't got around to installation yet. The problem I had with the PzIIIs was that the high/low 4 shaft GBs won't fit in there so you have to use 3 shaft and I didn't like the performance at all. It was way too fast and had very poor low speed performance. Then I put in the brass dual ratio with 380 motors (yes, they fit, just) and it's a thousand times better (IMO). I had the steel dual ratio GBs in it for a minute but I think the steel GBs are just way too loud so I put in the brass, but if I didn't have brass I'd settle for the steel dual ratio with 380s before I'd use a 3 shaft set. But that's just me.
