RCU Forums - View Single Post - Painted wing, stabs and advanced graphics
Old 01-02-2016 | 04:36 PM
  #149
Portlandflyer
Here we go on the main graphic.
The first thing I did was lay down a little bit of texture with the Gerald Mendez FX Artool texture stencil. I would guess that just about every custom painting shop in the world owns these stencils....they are that good.
I just start out laying a bit of texture in with the same blue I used before with some black mixed in.
I then lay out the masking film and put a piece of tape across the center. You can see that the larger 1/4 inch section has been removed. This will become the outside bevel.
I pull back half of the graphic and peal off the paper back and lay it down on the surface.
I then pull back the other half, peal off the paper back and lay it down. This method holds the masking film in position being applied.
Here I'm pulling the transfer paper.
And this is what we have.
The exposed area is shot with Metalume. Notice an arrow in the upper right. This indicates the direction of light.
Keep in mind if this was an actual beveled edge the side facing the light will be bright (highlight). The side facing away from the light will be in a shadow. At this point, I paint the shadow side only and will add highlights on the lighted side later. What I do is split the pointed parts with a piece of tape and spray thin black on the shadow side.
Here you will see all the shadows painted on the 1/4 inch (outside) bevel.
Now the 1/4 inch area is masked and I pull the 1/8 inch piece which will be the inside bevel.
Now I paint the shadow side on the inside bevel, which will be the opposite of the 1/4 inch (outside) bevel.
I then pull the film from the center part of the graphic and mask off the inside (1/8 inch) line.
Now I paint the inside of the graphic.
OK, now the tape and film is pulled to reveal the magic! You can see I have hand airbrushed a drop shadow under the graphic to make it stand out from the background.
Keep in mind if this was a true raised bevel, the 1/4 inch portion would cast a shadow on the center part of the graphic (red) here is mask and paint that shadow.
I now add the highlight on the front face of the bevels. I shoot white and then a bit of white pear over it and then a bit of Metalume.
ID:	2139284   Click image for larger version
ID:	2139285   Click image for larger version
ID:	2139286   Click image for larger version
ID:	2139287   Click image for larger version
ID:	2139288   Click image for larger version
ID:	2139289   Click image for larger version
ID:	2139290   Click image for larger version
ID:	2139292   Click image for larger version
ID:	2139293   Click image for larger version
ID:	2139294   Click image for larger version
ID:	2139295   Click image for larger version
ID:	2139296   Click image for larger version
ID:	2139297   Click image for larger version
ID:	2139298   Click image for larger version
ID:	2139300   Click image for larger version
ID:	2139301   Click image for larger version
ID:	2139302   Click image for larger version
ID:	2139303   Click image for larger version
ID:	2139304   Click image for larger version
ID:	2139305   Click image for larger version
ID:	2139306   Click image for larger version
ID:	2139308   Click image for larger version
ID:	2139309   Click image for larger version
ID:	2139310   Click image for larger version
ID:	2139315   Click image for larger version
ID:	2139316   Click image for larger version
